I have been tearing my hair out for a week now and thought I might consult the experts here about using network libraries with standard users in a VDI environment.
My firm is rolling out a set of dynamo scripts and have run into issues where packages located on network drives refuse to show up under “Add-Ons” in Dynamo. Whether installing the packages to a network folder OR adding packages already existing on a network drive, Dynamo generates an error like this:
Exception when attempting to load package BumbleBee from Q:\Dynamo\BumbleBee
System.IO.FileLoadException: Could not load file or assembly ‘file:///Q:\Dynamo\BumbleBee\bin\bumblebee.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
This happens to the most common packages in Dynamo (archilab, clockwork, rhythm, etc.) though not all (Springs seems to have no complaints about where it’s installed). I can install packages manually through package manager without issue. I can even successfully install packages locally, copy them from %appdata%\Dynamo\Dynamo Revit\2.0\Packages to a network location and have them fail when I add the new Node and Package Path and promote it to the default location. Finally, I can install packages to another location on the virtual C:\ and they will run properly.
Pertinent Information:
Revit Version: 18.32.
Dynamo Version: 2.0.3.8810 (Revit and Core)
Host Environment: VMWare ESXI 6.7 w/ Horizon View 7.8 and AppVolumes 2.16
VM OS: Windows 10 Enterprise
User permissions: standard user w/ R/W/E permissions over network share locations
Any ideas about the direction I should look to resolve this issue? I know it’s very difficult (impossible, even) to reproduce issues in a virtualized environment, but any feedback is appreciated.
Thanks.
