Need help with SectionView.ByBoundingBox
Hi all
Can i find a small help in figuring out the node SectionView.ByBoundingBox i need to know with a sample how it works with structural columns
What did you try so far?
The node is pretty much self explanatory.
You can double click the inputs (and also outputs) and it will give you possible
options for nodes you might wanna use / need.
Do you have any specific problems / questions?
Thanks for response but i don’t really think this is a proper workflow for this node
once i did it like ur script i selected a column as an element then i couldn’t find the section view symbol on my plan view another thing it gave me a section view with a crop region with column width and length
all i need to use this node or any other node to make section view a cross my column
Well, thats why it is important you give people as much information as possible.
Like what kind of Section do you need? Horizontal or vertical?
Does it need to cut the element etc.
What did you try yourself?
I am not sure the SectionView.ByBoundingBox if the way to go.
There are other nodes / ways do create Section Views AFAIK.
hi
try this
cordially
christian.stan
Thanks a lot, exactly what i wanted thanks very much :blush:
Hi
I am really blessed with your solution, and it works like pro, but for a discussion what if we needed to generate the section cutting the element in the middle like the red lines i draw in attached snapshot
The section box is defined by the Minimum Point (Section Plane) and the Maximum End Point of the viewing area.
If you want the section plane to pass through the axis of the column, you must set a Z component = 0 on the minimum point.
edit: if you look at the drawing of the icon, you see it
Sincerely,
christian.stan
Thanks a lot :blush:
