HI, here is the simple exercise of bringing the points from a series of coordinates I have in my spreadsheet, but I’m not sure what am I doing wrong. Any help will be highly appreciated. Thank you in advance.
go to settings, geometry working range. set it to extra large
Thanks Marcel, I did that but to no avail.
What I did now is to move my points closer to 0,0,0 by subtracting a certain known value and I did manage to bring my points.
The next question will be, how can I create a loft (with a certain thickness) from a series of tunnel profiles? Each profile consists of 51 points. There are about 43 profiles.
have you tried surface by loft?
and surface thicken?
if your point sequence is always the same for every profile, you can try ShiftIndices to get them in the right order
Create Guide curve from center points and use Surface.ByLoft with GuideCurve.
If you think those are all Arc’s then simply use Arc.ByBestFitthroughpoints node:
