Need a hand (Array İnput Type)
in this code
#Original code from @Einar_Raknes
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
#Converting input from Dynamo to Revit
line = UnwrapElement(IN[0]).GeometryCurve
ref = ReferenceArray()
ref.Append(line.GetEndPointReference(0))
ref.Append(line.GetEndPointReference(1))
#Create the dimension in a transaction
dim = doc.Create.NewDimension(doc.ActiveView, line, ref)
OUT = dim
the input node accepts only one input what should i need to change to make node accepts list inputs ???
i know the question is too simple but i may get permision to work on python with this node
You have a few options. You can modify the input line of code a little bit and add a for loop.
items = UnwrapElement(IN[0])
for item in items:
     line = item.GeometryCurve
Or you can wrap the python code in a custom node (if it’s not already) and set the lacing to Longest. Modifying the code may also require a few more changes to make your list structure work but both are viable options.
