@FC_GN8 I believe you are on the right track suggesting to create surface from cogopoints. I tried your dyn file its not working for me. My current layer is 0, my 50 polylines are on layer 1 so i changed your breakline layer to 1 and it ran and ran and ran with no end. Attached is my cad file for your reference called TEST_DYNAMO.dwg.
My thoughts were to approach it by converting my polylines to points by exploding them, but i am getting error unable to create line. I referenced other forum posts suggesting to up the scaling, which was the first error i got. Another article suggested the problem is now my polylines are to far away from origin, therefore causing the scaling issue, and the resolution would be to shift points to origin
unfortunately i cant turn the polyline into points to shift because of this error
below is my code (before trying to change origin)
any tips would be appreciated
