Natural surfaces
This is an unavoidable limitation of trimmed faces. Luckily, it’s quite easy to fix tri and quad planar faces because we can redefine them as untrimmed nurbs faces. Have a look at the “PlanarFaces.FixDomain” node from springs:
For more complicated trims however, you’re out of luck, and you’ll have to trim the resulting iso curves instead.
