I have used the same script as a colleague to PDF batch plot from Revit and it is not working. The script works on his but not on mine.
This is not the original Print PDF node from Archilab so it’s difficult to know what is the problem.
Maybe the “Print range” should be on Select instead of Current.
Have your colleague try it on the same project as you and see if that works. If so check the previews of each node in the script to see where they diverge. Also make sure you have the same package versions installed.
