Hey is there any chance that we can create multiple offsets for the alignmnet. Since i have 100s of alignments to work on but i couldnt find anything aligning to my requirement. i have gone through multiple offset polyline creation, but that file isnt working proper can anyone help me out.
You can use the node from The Civil Nodes package:
Do you have at least Civil 3D 2025.2?
i am using 2024 version. and moreover i need creating multiple offset. and when i checked in my friends system i am able to create 1 offset at a time and its not getting saved, if i change the anything previous work using dynamo is getting dissappeared
In 2024 you can use the Arkance Systems Node Library. Autodesk has changed a lot in 2025 which caused some incompatibility.
If newly created objects disappear, that happens because the element binding settings.
I wrote a blog about it once, it is in Dutch but you will find a translation button on top of the page.
i will upgrade to 2025. But do have anything solution for other issue mentioned regarding how to create multiple offsets…?!
Provide a list of offsets, names, stations, etc. and you should get what you need.
When i run based on the setting turned on its getting saved in drawing as well but when i run the pipeline again the previous ran using same pipeline is getting removed and new ran was getting generated. can’t I use pipline multiple times and get saved of all the data which i ran ?
