Is it already possible to add multiple Categories in the “Add shared parameter to Project” by archi-lab_grimshaw? I remember i’ve read somewhere in the discussion that they have added multiple categories but I wasn’t successful. Any idea how to do this? Thanks in advance.
By the way, I’m using Revit 2014 & Dynamo 0.8.2 because of the project requirement.
Hi!
You can try this way: http://dynamobim.org/forums/topic/shared-parameter-creation-from-list/#post-42001
But you should use the original version whith method “Autodesk.Revit.DB.Definitions.Create(string, Autodesk.Revit.DB.ParameterType, bool)”, if you are using Revit 2014.
Hi @Sergey_Krivoy Sergey, your link no longer works - where should I look for a solution to this?
Many thanks
