When I use Dynamo to create alignment, it only generates the first one from the list of polylines. Is there a way to fix this issue so that it creates alignments from all the polylines in the list?
Thank you for your response. I have the Civil3D Toolkit package, and I attempted to use the Dynamo files you shared. However, they are also not functioning correctly, as Iâm receiving warnings and the functions are reading as null.
I currently have Civil 3D 2025 installed, along with version 1.1.32 of the Civil3DToolkit in Dynamo. Unfortunately, this version does not include the âCreateAlignmentByPolylineâ node, and the downloaded file âCreateAlignments.dynâ is also nonfunctional. Could you please advise?
Hi
The .NET Framework was updated in C3D 2025 and Civil 3D Toolkit was joined into and replaced by Arkance package.
Anton Huzinga created a combined version and now itâs called The Civil Nodes.
You should be able to use the node âAlignment.CreateByPolylineâ instead
