Ehi everyone,
I’m here again asking for help
I did this easy script to place multicategory tags in views but one I run it all the tags are placed not where expected. This is an elevation view and the script in this case is made to tag facade’s glass.
12_ATK_Place tags in views.dyn (20.7 KB)
Any advice?
Thx guys in advance
@e.cietto ,
i am not sure, if it makes a difference… …check it ot
What about the message you have at the top of the node (yellow color)
Is your point of definition of the generic family at the center of the family?
Trying to use the Create Tag Node from the Genius Loci Package
to see if you have the same result
Cordially
christian.stan
This is what the message says,btw with the node from Genius Loci it does work. Dunno what the difference is, but it works.
Thx a lot
