MText.Create Node
does the “height” input not work on the MText.Create node?
What happen if you add a number using a code block instead of the number - node?
Does the Mtext.Create work if you run the script without any input for the height ?
That input is for the height of the text box, not the text height. The Civil 3D Toolkit has a node with an input for text height.
Hi, I use this nodes to set it
