Move TINSurface's into subfolder
Hello.
I’m creating a couple of tinsurfaces with dynamo and i want to put them automatically into a subfolder…
Does anyone know if this is possible? Or maybe someone has a node/code for this? :slight_smile:
HI
SEE THIS … PLS
Hi @genossealex,
This is possible with the nodes in Camber v3.0.0.
Hi @zachri.jensen
thank you for your reply, but i can’t find these nodes.
Which Civil3D and Dynamo Version do i need?
I tried it with:
Civil3D 2021 || Dynamo 2.5
Civil3D 2022 || Dynamo 2.10
Can you send a screenshot of the exact Civil 3D version (ABOUT command)? Also, are there any notifications up in the Dynamo menu bar when you install the package?
I know that i haven’t installed the latest updates.
Yes, you’ll need to either be on 2021.3 or at least 2022.1.
