Create Tin Volume Surface
Hello, Is there a node to create multiple volume surfaces?
I would select a base surface and all for comparison.
Check this similar question
https://forum.dynamobim.com/t/is-there-a-way-to-get-surfaces-volumes-from-dynamo/43767
Assem
Another one:
Update: there are dedicated nodes for this in the Camber package starting in v4.0.0.
Hi @zachri.jensen …
Why I don’t have this nodes. I’m using Civil3d 2022…Can you help me
Thanks You very much!
Look under CivilObjects → Surfaces
Hi @zachri.jensen
I cannot generate the volume surface, I have filled in the fields but an error appears, can you help me please, I attach images.
Thank you
Hi @zachri.jensen, Image to CAD
You are inputting strings for the surfaces, but they need to be surface objects.
Do you have any example please?
TY.
Here is an example:
You will get the surface dropdown in the Civil 3D toolkit package in Selection Library.
Hi @zachri.jensen
is it normal that no further tinvolumesurfaces are created if I use the function several times, but the existing one is always overwritten?
and once it exists, the used surfaces cannot be changed.
What does your graph look like?
it is nothing special…
It seems to be a problem in Civil3D 2021… It works in 2023.
2021.3 - Camber 4.2.1
2023.2 - Camber 4.2.1
Feels like a binding issue, but not sure. Does you get the same result in 2021 if you run it from Dynamo and not from dynamo Player?
/Patrick
If i run the script in Dynamo itself, it is still overwritting the VolumeSurface.
BUT now it is the same in 2023.
Check this one in 2023
