Moving multiple elements in XYZ
Good afternoon
I found a python script on the Internet.
# Import RevitAPI
clr.AddReference("RevitAPI")
#The inputs to this node will be stored as a list in the IN variable.
doc =  DocumentManager.Instance.CurrentDBDocument
app =  DocumentManager.Instance.CurrentUIApplication.Application
dataEnteringNode = IN
elementId = IN[0].Id
ElementTransformUtils.MoveElement(doc,ElementId(elementId),XYZ(IN[1],IN[2],IN[3]))
OUT = 0
This script works wonderfully if IN[0] is given one element.
How to make it work when multiple elements are fed into the input?
Hi @status_diamond ,
The easiest way to solve this is by wrapping the Python script into a Custom Node.
Then you just have to set the Custom Node input to @L2.
Do you know Custom Node for moving elements along XYZ? I can’t find. Thanks.
I meant that you’ll have to do that yourself.
However, for just moving elements you don’t need a custom Python script, just the Element.Location / Element.SetLocation nodes. Just make sure the new location is the old location + your translation.
I have already tried to move elements by changing their coordinates. But each element has its own parameter responsible for its position.
Plus, with simple nodes like this Element.Location / Element.SetLocation problem is not solvable.
I see,
Check out this guide on how to create a Custom Node:
https://primer.dynamobim.org/10_Custom-Nodes/10_Custom-Nodes.html
Try this
# Import RevitAPI
def tolist(obj):
	if hasattr(obj, "__iter__"):
		return obj
		return [obj]
elems = tolist(IN[0])
elems = [UnwrapElement(x) for x in elems]
[ElementTransformUtils.MoveElement(doc,e.Id,XYZ(IN[1],IN[2],IN[3])) for e in elems]
OUT = 0
Thanks! It works!
we can use directly this method for a list of element
  • ElementTransformUtils.MoveElements
Ah, yeah, fair enough!
