HI all,
How to move location of Elevation Tag without manual moving at the time of generate (Elevation generate automation through Dynamo).
Thank You
HI all,
Thank You
How did you create the elevation tags, with a node or with python? Cant you just give the create function another placement point, the point for the location where the tags should me moved to
I use this (ʳʰʸᵗʰᵐ|ElevationMarker.CreateElevationMarker) node for Create a elevation.
