I have to move elements on sheets with a certain amount. I have filtered out whatever I don’t want to move (titleblock, viewport etc.) and I’m left with a set of elements for each sheet. Lines, text notes, generic annotations mostly.
I have to move them, but the move by vector fails.
Attempt to modify the model outside of transaction
I did found the similar topics but the solutions were not matching my needs here.
Is there anything I can do?
Try and look into list levels and lacing.
I think levels are fine. The nulls are in the correct level. There is not too much I can change here, looks straight forward.
Are you creating any of these elements in the same graph?
No i had all the elements available.
Seems like the transaction start and end solved the issue and it is working fine.
The node still throws null tho, but at least works
hey i was wondering if someone could tell me how to take the coordinates from the model
I suggest open a new topic, this is old and not about coordinates.
