Transaction Node
i created a simple dynamo to move the elements by vector. Unfortunately i couldn’t achieve my target. the error is “Attempt to modify the model outside of transaction.” where we need to connect the transaction nodes.
Hi @SHIBUJOSE ,
I’ve never seen this occur before, does this also happen when you use Element.SetLocation after using the current x- y- and z-values together with the translation values?
Hello @SHIBUJOSE …yes think you need a transaction…
Revit_rHqzzHsjG9
Are you using stand alone version of Dynamo? I tried exactly you nodes. But same error.
No i am in 2023…anyway thats strange works nice here…does it work if you do something…
not working. same error. I am using Revit 2021
hmm what does the error say in your last image
can you save and upload your dynamo file?
yeah sure…does it work if you try this…
Home.dyn (13.8 KB) or this…its strange it works in 2023…
