Modifying Property Data Format
I’m developing a workflow to assign property data to corridor solids. That part is working :smiley:
I noticed, that if the drawing was created with the Civil 3D metric dwt, after exporting corridor solids, the automatically created “Standard” Property Data Format is set to Cubic Feet instead of Cubic Meters, thus creating wrong Automatic Property Data Value for Solid Volume.
This can be handled if the drawing is created from custom .dwt, (but sadly refencing the dwt not changing it). So as a fail-safe I try to override the units within the script, without success. The script runs successfully and sets the Unit Type, but not the Unit. Any ideas what am I missing here?
proba
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.Aec.DatabaseServices import *
from Autodesk.Aec.PropertyData import *
from Autodesk.Aec.PropertyData.DatabaseServices import *
dataEnteringNode = IN
editor = adoc.Editor
bit = IN[0]
with adoc.LockDocument():
    with adoc.Database as db:
            # Place your code below
            dict = DictionaryPropertyDataFormat(db)
            id = dict.GetAt("Standard")
            obj = t.GetObject(id, OpenMode.ForWrite, False, False)
            obj.UpgradeOpen()
            obj.BuiltinType = bit
            i = 0
            #API not helping with BuiltInUnit Enum, so let's find cubic meter
            while i < 350:
                ut = UnitType(i,10)
                utin = ut.InternalName
                if utin == "cubic_meter":
                    break
                i += 1
            #Set unit type
            #fut = UnitType(ut)
            obj.UnitType = ut
            obj.DowngradeOpen()
            #check
            utype = obj.UnitType.GetTypeDisplayName(True)
            utypeunit = obj.UnitType.InternalName
            # Commit before end transaction
            t.Commit()
            pass
OUT = utype, utypeunit, utin
Edit: Also, please help me understand what does Int32 mean in this case:
I wrote 10 in the constructor, and it seems to work, but I have no idea what i’m doing :smiley:
If you want to make sure that the units in the extracted .dwg file are set to metric in the Units for Legacy Drawings settings
If anyone interested, I figured it out I guess…it seems to be working
import sys
import Autodesk.Aec as aec
import Autodesk.Aec.DatabaseServices as aecdb
import Autodesk.Aec.PropertyData.DatabaseServices as aecpropdb
            dict = aecpropdb.DictionaryPropertyDataFormat(db)
            obj.UpgradeOpen()
            objut = obj.UnitType
            #define new unit type
            builtintype = aec.BuiltInType.Volume
            builtinunit = aec.BuiltInUnit.CubicMeter
            ut = aecdb.UnitType(builtinunit,96)
            #Set unit type
            obj.BuiltInType = builtintype
            obj.UnitType = ut
            asd = aecpropdb.UnitsType.Decimal
            obj.Units = asd
            # I'm not sure, if this is needed
            out = aecpropdb.PropertyDataFormat.Convert(obj,objut,ut)
            #check
            obj.DowngradeOpen()
            t.Commit()
            #pass
OUT = obj.Units,utype,utypeunit,objut.PluralName(False),ut.PluralName(False),objut.IsMetric,ut.IsMetric
