Hi Guys,
First time poster, and I’m still pretty “Green”
I would like to try and understand the difference between the two outputs in question, so that i can try to find a workaround if possible.
I have pulled parameter values from 2 different categories. They both read correctly and I can push new values to them using the Element.SetParameterByName node.
What I am trying to do is read the value of parameter from one category and push it to the parameter in a different category. Is this possible?
Forum won’t allow me to upload the .dyn file because I’m a new user(?), but i have attached screen shot for reference.
FYI - the error saying parameter name not found also confuses me because it still works. The parameter gets updated even when the error is still there. But if i change the Value to use as per red markup then value is not updated.
Hence i’m hopeing to learn the difference between the two values and why the category of the parameter matters when i just want it’s value to copied.
Thanks heaps!
