Hi all,
I was trying to get the surface of the modified floor points but still no success. as a start please see attached images of what im trying to do.
Thank you.
Hi all,
Thank you.
Hi @interactiverendering
Something like this should work :
But I get the feeling that dynamo is going to have a hard time getting the geometry of this floor… I came up with a bit of code as a workaround to a similar issue in the past. It could be improved but here it is :
from Autodesk.DesignScript.Geometry import Surface as DSSurf
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
import sys
pyt_path = r'C:\\Program Files (x86)\\IronPython 2.7\\Lib'
sys.path.append(pyt_path)
import collections
def tolist(input):
if isinstance(input,list):
return UnwrapElement(input)
return [UnwrapElement(input)]
def flatten(l):
for el in l:
if isinstance(el, collections.Iterable) and not isinstance(el, basestring):
for sub in flatten(el):
yield sub
yield el
def tostring(x):
return x.ToString()
def getgeomlist(x,opt):
return list(x.get_Geometry(opt))
def getlength(c):
return c.Length
def getfaces(x,opt):
#getting geometryelements as list
geomelems = getgeomlist(x,opt)
#getting nested instance geometry for all geometry instances
while any('GeometryInstance' in g for g in map(tostring,geomelems)):
for index,i in enumerate(geomelems):
if 'GeometryInstance' in i.ToString():
geomelems[index] = i.GetInstanceGeometry()
continue
geomelems = list(flatten(geomelems))
#getting all faces, keeping meshes
faces = []
for i in geomelems:
if 'Solid' in i.ToString():
faces.append(list(i.Faces))
elif 'Mesh' in i.ToString():
faces.append(i)
continue
faces = list(flatten(faces))
return faces
geomoptions = Options()
fcs = []
elems = tolist(IN[0])
for e in elems:
faces = getfaces(e,geomoptions)
tlist = []
for f in faces:
try:
tlist.append(f.ToProtoType(True))
except:
edges = list(f.GetEdgesAsCurveLoops())[0]
dsedges = [e.ToProtoType(True) for e in edges]
crosssections = sorted(dsedges,key = getlength)[-2:]
loft = DSSurf.ByLoft(crosssections)
tlist.append(loft)
fcs.append(tlist)
OUT = fcs
No problem
What is your end goal?
I tried that already but it’s not getting the boundary of top surface(modified floor points height) just the sketch whic is flat
Just as a workaround proposal, selecting the faces directly on the model with Springs.SelectFaces+ would not fit your needs?
I see. This should work :
-get the geometry of top faces as shown previously
-join the surfaces with polysurface.byjoinedsurfaces
-get the perimeter curves of the polysurface
Great! Thank you very much Mostafa
could work also i’ll try this as an option for now…Many Thanks
