Hi!
I am afraid that the element sketch might be always flat, regardless to modified elevations of it’s points (it is so in Revit).
You can try the code below. Rather than using sketch it extracts edges from top faces of the floor and tries to remove duplicates/internal edges. Seems to work. As a result you can get a 3D polycurve with elevated points.
floors = UnwrapElement(IN[0])
clr.AddReference("RevitAPI")
output = []
for f in floors:
curve_list = []
top_face_refs = HostObjectUtils.GetTopFaces(f)
top_faces = []
temp_edges = []
#get all edges
for face_ref in top_face_refs:
face = doc.GetElement(face_ref).GetGeometryObjectFromReference(face_ref)
if not face is None:
top_faces.append(face)
edge_arrays = face.EdgeLoops
for edges in edge_arrays:
for e in edges:
temp_edges.append(e)
#remove internal edges
for e in temp_edges:
f0 = e.GetFace(0)
f1 = e.GetFace(1)
valid = False
if f0 is None:
valid = True
if not f0 in top_faces:
valid = True
if f1 is None:
valid = True
if not f1 in top_faces:
valid = True
if valid:
#edge_list.append(e)
c = e.AsCurve()
curve_list.append(c.ToProtoType())
output.append(curve_list)
OUT = output
