Modeling Beams From Cad Dynamo Revit
what can i do the center line of the beam to dynamo
Hello @t361666QRPEF and welcome to the forum :wink: im not sure i understand probably “get.location” or in newer version "actual location maybe
Beam width is not the same
how can i do get beam cente
r
I’m using CAD to create beam center
How to use dynamo~~
arhh now i guees i understand, thats another thing ;)try group you paraelle cad lines, loft to surface and find the middle with isocurves maybe
these nodes here can probably help you
S-3FL.dwg (185.0 KB)
dynamo is wrong~~
no dynamo is not wrong, guess something other is wrong :wink: i take a look later
try something here
Revit_0heaS5BXVk
can provide dyn.?
no try play around with it, and if you go stuck, then show your graph here and we can help from there…nobody will learn anything with just give finish solution :wink: cheers
group distnace is wrong
Can script nodes be separated?
no it isnt, you will need a radius in your sphere, try with 60 so you are sure they intersect, not sure i understand what your mean with separeted
I can’t see all node
by union can not
which revit version are you in, and which version is your spring node ? and you are sure the sphere intersect ? as here
PS i work in millimeter here…and when you get it work the groupnode…then try as here
if you are in meter…then radius 0.06 and 0.01 in margin in spring nodes
wrong~~~~~~
