Revit structural framing from Dynamo lines
I am new to both Revit and Dyanmo. I was able to create the geometry that I want in Dynamo and now I have to transfer it to Revit. I used the component StructuralFraming.BeamByCurve. It works pretty decently but the beam sections are rather assigned using the Dynamo lines as a top limit instead of the center line. I would like the beams to show up using the Dynamo lines as center lines. The Revit model ends up with all kinds of offsets and isn’t useful otherwise.
Thank you,
@kmsaaf Try this:
Thank you! This helped solve the issue. Setting all the elements z Justification to Center fixed the issue.
