This is my first shot at creating a custum node for mirroring (without copy) a sectionview.
So bear with me
Revit 2017.2, Dynamo 1.3.2
I copied some Python code from another node that i used to get me started and needs to be cleaned up a bit
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import ElementTransformUtils, Plane
walls = UnwrapElement(IN[0])
planes = IN[1]
rvt_planes =list()
mirrored = list()
count = 0
def Dyn2RvtPlane(pl1):
normal1 = pl1.Normal.ToXyz(True)
origin1 = pl1.Origin.ToXyz(True)
return Autodesk.Revit.DB.Plane(normal1, origin1)
for p in planes:
rvt_planes.append(Dyn2RvtPlane(p))
for w, rp in zip(walls, rvt_planes):
try:
item.Flip()
ElementTransformUtils.MirrorElement(doc, w.Id, rp)
count += 1
except:
count += 0
OUT = "%s elements mirrored" %count
This will mirror/copy my sections using the Revit Origin.
What i want is to mirror the sections on their own plane (flip) without a copy.
The part with ElementTransformUtils.MirrorElement(doc, w.Id, rp) needs a fourth argument (false) to prevent it making a copy, but if i do this nothing happens.
Creating new views is unwanted because the views are on sheet already, just filpped
i need a push in the right direction here, can someone help?
mirror_flip_sections.dyn (7.4 KB)
You you please format the code using the “</>” option as your codes formatting is otherwise lost and as Python is indent sensitive it would require people trying to help you to go through your entire code for indentations…
Cant get it right with indents, tying to find a solution here, but its in the .dyn anyway…
@Jonathan.Olesen
its now in the first post
I have gotten as far as…
perhaps some python gurus would like to chime in… as “expected Plane, got Plane” is not very helpful
planes = IN[1]
rvt_planes =list()
mirrored = list()
e1=[]
count = 0
for p in planes:
rvt_planes.append(p)
e1.append(w.Id)
Icoll = List[ElementId](e1)
ElementTransformUtils.MirrorElements(doc, Icoll, rp,1)
@m.rijsmus The reason that original code wasn’t working is because when mirroring a section view, its not the view itself that’s meant to be mirrored, rather the section viewer/annotative element. It turns out that the Element ID of a section’s viewer is one less than the section view’s Element ID which is fortunate for making this work with inputting the view itself; this modified script will get the section viewer’s element ID from the section view. I also combined the method from the Clockwork node’s View.Plane Python script within it.
Here is a working script:
sections = IN[0]
if not isinstance(sections,list):
sections = [sections]
#get View Plane to use as the Mirror Plane
def getPlane(s):
s = UnwrapElement(s)
origin = s.Origin
normal = s.ViewDirection
plane = Autodesk.Revit.DB.Plane.CreateByNormalAndOrigin(normal,origin)
return plane
#get the Element ID for the Section View's Annotative Viewer
def getViewer(s):
viewerId = ElementId(s.Id - 1)
return viewerId
def flipSection(s):
ids = []
ids.append(getViewer(s))
Icoll = List[ElementId](ids)
rp = getPlane(s)
ElementTransformUtils.MirrorElements(doc, Icoll, rp, False)
return s
count = 0
for s in sections:
try:
flipSection(s)
count = count + 1
except:
pass
