SectionView from SectionLine in Python
Hello Dynamo Community :slight_smile:
I want to get SectionViews from SectionLines in active view.
I can
  • get the view names of the Sectionlines
  • get the view name of all SectionViews
now im struggling at comparing names and get the views from there
import System
clr.AddReference('RevitAPI')
sectionNames = []
# get sectionlines in active view
sectionlines = FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Viewers).ToElements()
# get viewname parameter
for sectionline in sectionlines:
	sectionNames.append(sectionline.Name)
# get all views in project
allViews = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Views).ToElements()
viewNames = []
views = []
# get viewnames of all views in project
for allView in allViews:
	viewNames.append(allView.Name)
# find view by name
for viewName, sectionName, allView in zip(viewNames, sectionNames, allViews):
	if viewName == sectionName:
		views.append(allView)
OUT =  views
You can use loop in loop in this case so it can check all of them one by one.
In your script, each item of lists are compared with only the same order, so it canโ€™t find match.
Not sure this is the best way, but it works.
for sectionName in sectionNames:
	for viewName,allView in zip(viewNames,allViews):
			break
And your script makes too many temporary lists which are not necessary.
The more list making the more time taking.
import System
views = []
	sectionName=sectionline.Name
		viewName=allView.Name
			break #stop looping if match found
OUT =  views
Thank you for your help and explanation @Hyunu_Kim :slight_smile:
