Hi, all
Recently I have an task - transfer Civil 3d’s designed surface (with linear triangulation) with absolute accuracy to Revit. Since Revit 2020 there is method below: Create Method (Document, IList(XYZ), IList(PolymeshFacet))
As small case - we’re successfully translated 13-km rail-based surfaces with ~80 000 points during ~15 minutes to Revit (file’s size ~15 Mb). As a disadvantage - there are no opportunity to set internal/outside borders (no API’s methods).
P.S. I know about practice load topo from BIM 360 - but that product can’t be used at state companies.
Hola Amigo @georg.grebenyuk como estas??
Thanks for your work an effort, I’m testing your package, but i think i missing something the node MainClass.CreateTopo gives me null even when i put the lacing to longest, could you please help me a little bit please??
Hi, Gilberto, it return a null because the result of node in a process of creating a toposurface in Revit environmental; thus, check updates in model to find that surface. … or any toposurfaces are missing in model in script’s finishing?
Amigo @georg.grebenyuk, my bad, beginers mistake!! the visibility of Topography category was not checked in the template that i used, i clean the points manually to have the same results that your node, thanks again for your package, works fine!!
