Mesh to geometry
Hello everyone! Due to some circumstances, I need to run the dyn file that was originally applicable to ‘geometry’ on ‘mesh’, but now I have discovered some issues:
I have always believed that mesh is also a type of geometry, but the phenomenon here seems to be different. Is there any way to convert mesh into geometry?
My Revit version is 2022, and the Dynamo version is 2.10
Mesh is a type of geometry, but it’s far enough removed that what you can do with a brep (the other geometry types) you can’t do with a mesh. Convert it to a polysurface first, and you should be all set. I believe Springs has a node for this.
Hi @2899778163 havent tried but could element bounding box work
thank you so much!
