I want to convert Dynamo geometry to Revit and convert the geometry to the roof properties in revit
So I tried using the “ImportInstance.ByGeometries” node
But can not completely become geometric, what did I miss?
How do I turn the geometry into a roof?
Yna_Db
2
ImportInstance.ByGeometries is not the only way to import geometry into Revit. You can try other available methods and thereby clarify your request. You will also find lots of information outside of the forum that will help you to refine your approach:
http://dynamoprimer.com/en/05_Geometry-for-Computational-Design/5-8_importing.html
http://dynamobim.org/learn/
