Mesh.ByGeometry returning null but still creating a civil3d mesh which is missing many triangles
Hello all,
I am trying to send a Dynamo mesh to civil3d using “Mesh.ByGeometry” node. It is working but the resulting mesh is missing many trianlges. The node is returning null instead of “Mesh” object.
Dynamo mesh:
Civil3d mesh:
Dynamo script:
MeshByGeometry.dyn (24.0 KB)
Example file:
I do not know what is the problem here. Other simpler meshes are being created just fine.
Thanks in advance!
I know its an older question. But maybe its not a scripting problem but an AutoCAD Limitation. AutoCAD can create and process polyface mesh surfaces (PFACEMESH, AcDbPolyFaceMesh (the command PFACE) up to the size of 32767 vertices.
Still thanks for the reply. I also think so because smaller meshes were being created just fine. It doesn’t matter now cause I remember I found a workaround that works.
