Hi All,
I’m tying to Merge cells in a table, but I’m receiving this error:
- TypeError: No method matches given arguments for MergeCells: (<class ‘int’>, <class ‘int’>, <class ‘int’>, <class ‘int’>)
clr.AddReference(‘AcMgd’)
clr.AddReference(‘AcDbMgd’)from Autodesk.AutoCAD.ApplicationServices import *
from Autodesk.AutoCAD.DatabaseServices import *def table_mergecells(tableObj):
errorReport = Noneif not tableObj: return adoc = Application.DocumentManager.MdiActiveDocument output = [] with adoc.LockDocument(): with adoc.Database as db: with db.TransactionManager.StartTransaction() as t: #oid = tableObj.InternalDBObject #acTbl = t.GetObject(oid, OpenMode.ForWrite) try: print("MergeCells") acTbl = tableObj.InternalDBObject acTbl.UpgradeOpen() acTbl.MergeCells(0,1,0,3) acTbl.DowngradeOpen() t.Commit() # Error handling except: import traceback errorReport = traceback.format_exc() print("The process failed") output.append(errorReport) else: errorReport = "The process completed" print("errorReport: The process completed") #print(selObjects) output.append(tableObj) finally: #print("finally") return errorReport
tableObj = IN[0]
print(“=== table_mergecells ===”)
retvalue = table_mergecells(tableObj)OUT = retvalue
see:
What is issue here?
