I am trying to add an appurtenance to at a point and am getting a type error when using the Civil3d API AddAppurtenance method in the PipePressureNetwork class. I am inputting a point3d and pressure part size but it says there is no method to match the given arguments.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
from Autodesk.Civil.DatabaseServices.Styles import *
dataEnteringNode = IN
obj = IN[0]
point = IN[1]
xyz = [point.X, point.Y, point.X]
pt = Point3d(xyz)
app = PressurePipeNetwork.AddAppurtenance(pt, obj)
OUT = obj
