I am using RVT 2022 and Dyn. 2.10. Currently I am struggling with this ERROR: Warning: TypeError : No method matches given arguments for Create: (<class ‘Autodesk.Revit.DB.Wall’>, <class ‘Autodesk.Revit.DB.Document’>, <class ‘Autodesk.Revit.DB.Line’>, <class ‘Autodesk.Revit.DB.ElementId’>, <class ‘bool’>) [’ File “”, line 34, in \n’]
Under my understanding, I am not calling that method. You will find the script below. I would really appreciate your support.
Thanks for your time.
import sys
clr.AddReference('RevitAPI')
Doc = DocumentManager.Instance.CurrentDBDocument
Lines = IN[0]
LevelId = UnwrapElement(IN[1]).Id
Walls = []
RVTLines = []
for line in Lines:
RVTLines.append(line.ToRevitType())
TransactionManager.Instance.EnsureInTransaction(Doc)
for RVTLine in RVTLines:
Wall = Wall.Create(Doc, RVTLine, LevelId, False)
WallWraped = Wall.ToDSType(False)
Walls.append(WallWraped)
# Place your code below this line
OUT = RVTLines
