Hi, I’m trying to export my materials from the model space and the attached works but they materials populate side by side in the excel instead of vertically. I’m fairly new to Dynamo so any tips are appreciated. Thank you.
Maybe first combine all your elements into 1 list and then pass them into the getparametervalue. Each new list will be a row in your spreadsheet. You might play with removing the transpose node and see if that is the result you are looking for.
Great place to start.
