Making rebar solid
Can anyone tell me why this isn’t working?
I am using Revit 2016 R2 Update 2 , Dynamo 0.9.1.4062, Dynamo for rebar 0.2.7
I’m trying to toggle the appearance of rebar in the current view between solid and line. If I put the same code in a script that creates rebar it works. But this doesn’t when I select existing rebar.
Thanks for your help.
I’ve had some similair issues, but from Dieter Vermeulen’s blog I’ve found a solution that works flawlessly for me:
Hello, the code doesn’t work for me using it in a existing rebar. Someone did it work ?
To get existing bars in Revit to appear as solid you have to change it in Revit.
PÅL RØE LARSEN:
Thanks, but I want to make it automaticaly from Dynamo.
Check out this video. In there, he is able to do it automaticaly with dynamo aparently.
Thanks in advance
Hmm. I’ve never seen that interface before, but I really don’t feel its much different though.
In my work I’m using either the Dynamo-code I posted or the View Visibility Settings in Revit, which works fine with me :slight_smile:
Thank you for your response.
@Eduardo_Dilo
If you’re still interested, see this issue https://github.com/tt-acm/DynamoForRebar/issues/72
Try this custom node until it’s fixed:
Rebar.SetSolidInView.dyf (3.8 KB)
Hi PÄl, I’m trying to use your script for all of the bars in the 3D view. This is like my script looks like. Why isn’t working?
I think the fault lies in your Rebar input in the Rebar.SetUnobscureInView node. As you can see in my post from March 7th I input the Rebar outputted from the Rebar.ByCurve node into the SetSolid node. I see that you use an Element Types node. Try switching to your output from the Rebar.ByCurve node. That should do it I think :slight_smile:
Yes, I saw that, but I’m trying to do this through a rebar which is already placed in my model, not created though Dynamo. Is it only working witch bars created through Dynamo?
Thanks!
Aah, ok. Hmm, I think my method only works with rebar generated from Dynamo. However, Im pretty shure Dynamo can handle existing rebar. I have not tried it though :confused:
Thanks! If I find the way… I’ll post it!
Hello @Jorge_Villarroel , you can use the attached custom node or the below python script to set the rebar unobscured in view.
Rebar.SetUnobscuredInView.dyf (3.7 KB)
clr.AddReference('RevitAPI')
clr.AddReference("System")
rebarElements = UnwrapElement(IN[0])
views = UnwrapElement(IN[1])
#Change rebar in transaction
for view in views:
	for rebarElement in rebarElements:
		rebarElement.SetUnobscuredInView(view,1)
OUT = rebarElements
Thanks!
Hi @Einar_Raknes,
I’ve tried inputing your code and I’m getting the following error:
File “”, line 29, in
TypeError: iteration over non-sequence of type View3D
Any Ideas?
Cheers
Brenden
Hi Brenden,
Can you show us complete screenshot of your graph?
@Brenden_Picton The view must be in a list.Use List.Create or { 3d }; in a codeblock. If you download the custom node, it will take care of this for you.
@Einar_Raknes,
Works perfect now, thankyou.
Cheers,
Brenden
Thanks for sharing your code, @Einar_Raknes.
I made some improvements for my implementation and thought I’d post it back.
It now accepts single rebar objects and selections that include other objects.
clr.AddReference(‘RevitAPI’)
clr.AddReference(“System”)
clr.AddReference(‘RevitNodes’)
for view in views:
#Check if single rebar is selected
if type(rebarElements).name == “Rebar”:
rebarElements.SetSolidInView(view,1)
#Check if object is rebar
if type(rebarElement).name == “Rebar”:
rebarElement.SetSolidInView(view,1)
OUT = rebarElements
