Can be show solid Rebar of Model Link on Revit 2022
Hi all
in Revit 2023 can be show solid Rebar of Model Link on level Fine.
But using Dynamo can be show solid Rebar on Revit 2022
Thank Advance!!
You will need to show the python nodes code, otherwise we do not know what is the issue.
Though it would seem that you are making a change to revit outside of a transaction, so you will need to add a start and end transaction within your code.
side note that their is a set solid method within the api - SetSolidInView Method
Thank Brendan!!
I want set solid of Link model so Transaction warning outside.
(Sorry I dont type ‘Model Link’)
Seem like can not set solid element of model link.
