I can’t figure why this this graph bellow starts and never completes to make the floors on the rvt attached follow the toposurface. I press run and forget about it. An hour later it is still running.
I guess it’s some step I missed when projecting the points to the topo geometry. Should I be concerned about reversing the Z axis just for the points above the actual toposurface?
I tried to bypass the convert to polysurface step. Got a warning:
Warning: Point.Project expects argument type(s) (Point, Geometry, Vector), but was called with (Autodesk.DesignScript.Geometry.Point, Autodesk.DesignScript.Geometry.Mesh, Autodesk.DesignScript.Geometry.Vector).
I also noticed the stripped model I provided has units set to milimeters, which is awful to Dynamo. I converted to meters and at least finished processing.
Another attempt, converting the toposurface mesh to polysurface.
Warning: Point.Project operation failed. Unable to create intersection boolean : INCONS_VERT_ATT – inconsistent information in vertex and coedge attributes
