I’d like to make 2 lists with “OA” and “25”, with their sublists but not with “OA” or “25” written in each first item of them. How can I do ?
Also, if I have OA, 25 and BC for example, I think this method doesn’t function ?
There’s no need to flatten your groups. The whole reason you have them grouped is to keep OA and 25 separate. This would work with as many groups as you’d need.
Edit:
If you don’t need the identifier you can either remove it before grouping or after (if you want to double check that everything sorted correctly.)
