Who can help me to find a way how to group my list values by A001, B001, C001 in this case and create sublists? The string structure XX-XXX-XXXX would be the same at all times.
On the right is the list I’m looking for.
Thanks.
an issue with Python
lst_header = IN[0]
lst_b = IN[1]
fun = lambda x, lsty : [ x ]+[y for y in lsty if y.endswith(x)]
OUT = [fun(x,lst_b) for x in lst_header]
or only with the full list XX-XXX-XXXX
full_list = IN[0]
set_header = set([(x.split('-'))[-1] for x in full_list if (x.split('-'))[-1]])
fun = lambda x, lsty : [x]+[y for y in lsty if y.endswith(x)]
OUT = [fun(x,full_list ) for x in set_header]
Look good. Thanks! But quite hard to read this syntax.
here is a version without lambda function and list comprehension
full_list = ['11-001-A001','03-003-B001', '05-002-C001', '02-023-B001', '06-013-A001','-']
#loop for get the header
lst_suff = []
for item in full_list:
#get suffix
suffix = item.split('-').pop(-1)
#check if value
if suffix :
#add to list
lst_suff.append(suffix)
#remove duplicate
set_header = set(lst_suff)
#create group
out_list = []
for header in set_header:
#creatsublist
sublst = []
if item.endswith(header):
sublst.append(item)
#insert the header
sublst.insert(0,header)
out_list.append(sublst)
OUT = out_list
