I am trying to find a solution to our lighting fixtures being moved over when Arch are frequently updating their model. Communication between the Architect firm and our MEP team is too slow where the MEP team is not getting the latest ceiling grid fast enough. Essentially, I am trying to find a way where the lighting fixtures shift to the next available grid while still keeping the lighting layout/design.
I been looking at Dynamo as a possible solution since I could potentially create a python script but want to know if anyone has found a solution to the following problem? I never used Dynamo and have some experience with programing, however, I don’t want to reinvent the wheel if there’s already a method out there.
If Dynamo is the best solution, are there any recommended articles or examples that I can use to reference for this particular problem? Is there a possibility to connect to the linked ceiling from the linked Revit model obtained by the Architect firm? If so, then I’m assuming I would be able to get the information on the grid layout. From there I guess I can select the lighting fixture family and ensure that it is within the grid, if not shift over while maintaining the same layout, assuming the Architects didn’t add new walls that would conflict the design.
The following are forums that I found that could help but not sure if the either the Sparrow or Genius Loci package would be the solution. Very new to Dynamo so I would need to do further research.
Any thoughts or advice would be greatly appreciated!
