Hello com.,
as part of my bachelor thesis I programmed a parametric building in Phyton.
I want to import the parameter(s) to Dynamo.
I have converted python code into an xml file.
Now I want to import the xml file to dynamo.
I read that the “lunchbox package” provides the necessary features to do that.
I already downloaded and installed the package, but somehow I cant find it in Dynamo.
I searched for a tutorial/ dynamo forum post, but didnt find any current article.
I installed via dynamo version 2018.7.7, but I cant find e.g. “DataSets.DeserializeXML, DataSets.SerializeXML”
Can you help me/ explain to me how I install the current version of lunchbox package into Dynamo?
The lunchbox package is installed here (default):
C:\Users\Max\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PROVING GROUND\LunchBox
(My thought process:
As an example, I created three walls in Revit and want to export them to a xml file (screenshot) to get an idea how it looks like.
After that, I want to import my xml file with the parametric building to dynamo.)
Using Revit 2021.1.2
Thank you!
