Good morning,
using Dynamo version 1.3.4 with Revit 2019.2.
LunchBox nodes no longer work, how can I replace them?
I attach photo script
thanks for the tips
Reinstall the lunchbox package. Replace renamed nodes as needed.
I tried but it doesn’t work
What doesn’t work?
The installation (has to be done via the lunchbox exe so it may need to be unblocked or allowed by your IT)?
Replacing the nodes (someone renamed them so the exact names will not appear)?
LunchBox
The installer?
I tried to uninstall and install the lunchbox package of different versions but I can’t extract the required parameters
Are the nodes still unresolved (red color)?
yes
Then you will need to replace the node with a new version as it appears to have changed names/GUIDs since you last had this working.
I do not know what the node is as the name has been changed.
JacobSmall is correct you will need to reinsert the new version of the node after installing a new version of Lunchbox compatible with the 2019 Revit API.
How are you installing Lunchbox? If I recall they moved off the package installer to an .exe installer (combined with the grasshopper installer) from their website. Which means the latest version on the package manager is not really anything new or compatible with 2019.2 Revit as the last version on the Dynamo Package Manager appears to be for 2018 Revit.
