I am trying to use “GetXMLNode” in lunchbox package to read an XML file and select my required data. I read this post “Integrating XML with Dynamo via LunchBox”, http://www.theprovingground.org/2015/04/integrating-xml-with-dynamo-via-lunchbox.html
but I don’t understand the 2nd diagram, how to show an XML file and its content in dynamo?
I use readtext to read an xml file, it shows I lost all my tagnames, so I am not able to use “GetXMLNode” to select my value.
I add the xml as the attachment, but change it as txt file. May save it as xml.
Thank you!
sample.txt (351 Bytes)
