Is anyone else having issues with LunchBox no longer working, especially in the latest daily build?
Lunchbox seems to be running fine for me. Tested some panel and structure nodes. I am running DynamoInstall0.8.0.20150312T1814 (latest build).
I am however running into problems with Rhynamo (specifically writing files to Rhino). Attaching link here in case this may be an update issue.
http://dynamobim.com/forums/topic/writing-files-to-rhino-rhynamo-null/
When I tried to used Lunchbox I was getting an error at line 12 - “clr.AddReference(“RevitServices”)”. It’s really weird. I copied the entire script, without any edits, into a new Python node and it works fine. I have no idea why it would do this…
archi-lab packages are not working either in the daily build and I am experiencing the same issue. Ideas?
its the “#clr.AddReference(“RevitServices”)” part of the script. Dynamo is not loading the dll as expected. A bug in the latest version I guess…
I’ve replaced this line with this and it works: clr.AddReferenceToFileAndPath(r"C:\Program Files\Dynamo 0.8\Revit_2015\RevitServices.dll")
