Issues with LunchBox Installation
Is there any way to install LunchBox for Revit 2019 with Dynamo 2.0?
I tried to install it numerous times with no luck. I installed it independently from their website but same problem the package don’t show in Dynamo and I can’t even find the installation directory?
Any ideas on how to get this running?
It works fine now after re-starting windows.
Anyone know how to get past this:
Capture
I tried right-click and see now way to run this as admin or ignore this being blocked. I do not have IT. This is my computer. No special setup.
Did you find any solution about this problem?
@Paul_Aubin @habakay Not sure if you have fixed your problem. The following website shows the solution.
Thanks for that. I just tried again on both of my systems and it installed fine. So seems the problem sorted itself. But I will keep this post anyhow for future reference. Thanks.
