Lunchbox Create Room By Name - does not create the all the rooms in the list
Hello Everyone,
I’m having issues with creating the rooms from excel using the lunchbox node to create the rooms in Revit - Node name: Lunchbox Create Room by Name and Number. I managed to pull a list that I want from an excel file but the node can only create 15 rooms compare to 198 rooms that are on the list. Anyone of the same experience who has a solution?
P.S. I wanted to attach the relevant file but I was not allowed to do so because I’m a new user.
Cheers,
Audi
Please show a picture of your graph with previews enabled :slight_smile:
Hi Jonathan,
Here is the snap shot of the dynamo script.
Regards
Audi Capellan
BIM Manager
Aedas
Architecture+Planning+Landscape+Interiors
10 Hoe Chiang Road #11-01 Keppel Towers, Singapore 089315
D +65 6464 1741 | F +65 6734 6233 | audi.capellan@aedas.com
www.aedas.com
ü
please consider the environment before printing this e-mail
It’s probably the null values in your list of room names that makes the node fail.
If you don’t input a name and a number, Lunchbox Create Room by Name and Number will not create a room…
My thought is the same as what @Alban_de_Chasteigner says… You could replace the nulls with dummy values, but you would end up with a large range of unwanted rooms, the best solution would to sort/clean your list properly before creating the rooms :slight_smile:
Hi Alban,
Thanks. I will remove all the null values and try again.
Regards
Audi Capellan
BIM Manager
Aedas
www.aedas.com
ü
