Hi All
Im new to dynamo and I dont really understand the logical flow behind the program. When you start off in a program you generally work on a flow from left to right, top to bottom. Dynamo… I dont know. Take getparameterbyvalue for example. There is element, parameter name, and var in the block. What are inputs and what are outputs?
Then Element.SetparameterByName. There is element, parametername, value and element in the block. What are inputs and outputs here?
If I could get a page or something to explain what each library item does it would make more sense
