my first post here
I hope you can help me to solve an issue.
I received a Revit project, which all its facade is a mass family that contains different adaptive curtain wall families applied on a SAT object.
I am trying to obtain the location points of all these adaptive families with the AdaptiveComponent.Location node, but for one of the family types -the one that populates the corners- the points are strangely retrieved far from the actual object and in a much smaller scale.
Inside of the family I’ve tried to change Host and loop system to host or global, but so far no results. I also verified that the units in the host and adaptive families are both set in mm.
Thanks in advance!
revit 2017
dynamo v. 1.2.1
but here a screenshot: 6 Adaptive points that adapt to the surface curvature.
