Location of a point with respect to survey point?
I am trying to find the location of an element with respect to survey point but instead I am getting it w.r.t to project basepoint. Can someone help me to achieve it?
Project basepoint is rotated w.r.t true north also.
@j.sunny9PYH6
that can be a starting point…
Thanks. Let me have a look. It seems it finds distance between the 2 points.
Here is an example with Python
import sys
import sys
#import Revit API
clr.AddReference('RevitAPI')
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lst_DSPt = toList(IN[0])
out = []
for pt in lst_DSPt:
    pt = pt.ToXyz()
    #translate point from  Internal to Shared coordinates
    translatedpointB = doc.ActiveProjectLocation.GetTotalTransform().Inverse.OfPoint(pt)
    out.append([translatedpointB.ToPoint().X, translatedpointB.ToPoint().Y, translatedpointB.ToPoint().Z])
OUT = out
