Get Location as point, how?
how do i get the Location of my Instances as Point ?
clr.AddReference('RevitAPI')
elements = UnwrapElement(IN[0])
points =[]
for e in elements:
	points.append(e.Location.ToPoint())
OUT = points
ToPoint does not work
grafik
KR
Andreas
Have you tried setting them to ToDSType(True)
points.append(e.Location.ToPoint().ToDSType(True))
@Alien ,
points =[]
for e in elements:
OUT = points
no
@Alien ,
so i got the points BUT scaled, why? i need just a point from my door … it makes no sence
is there a simpler way, have i to convert each point X,Y,Z to metric system ?
# Phython-Standard- und DesignScript-Bibliotheken laden
import sys
doors = UnwrapElement(IN[0])
locations = []
Points= []
for door in doors:
	location = door.Location
	if location:
		point = location.Point
	if point:
		locations.append(point)
for i in locations:
	Points.append(Point.ByCoordinates(i.X,i.Y,i.Z))
OUT = Points
Try [i.ToPoint() for I in revitPoints]
The values are likely returning in feet not in meters, which would cause this type of scaling issue. If my method doesn’t work at the right scale, multiply by the scale factor for your units in your method.
Edit: you might need to increase your imports as well.
# Import geometry conversion extension methods
hello,
points =[]
for e in elements:
    a=e.Location
    points.append([a.Point.ToPoint(),a.Point])
OUT = points
cordially
christian.stan
@christian.stan @jacob.small @Alien ,
i did this way
grafik
import sys
locations = []
Points = []
for door in doors:
    if location:
        point = location.Point.ToPoint()
    if point:
for i in locations:
    Points.append(i)
OUT = Points
@christian.stan ,
your scripte creates that
grafik
There are only 15 lines without the attached script
odd
cordially
christian.stan
